APN settings not working on android
  • 7 July 2020
  • 67 views
I can’t seem to get internet access on my phone after switching networks.
I have gone through advice on APN and still cannot get it working :(
https://www.idmobile.co.uk/help-and-advice/get-your-settings
Hello @soladragon,
Which phone are you using?
Are you in the UK or abroad?
Can you please try deleting your current APN settings, then add a fresh new setting with the above APNS.
(won’t work if you change existing ones).
Deleting & re-adding refreshes the network settings and usually fixes this.
