Hi, my Mum’s Motorola G7 Play is on iD Mobile and tonight, on more than one occasion, the call went silent after 15 minutes. It doesn’t happen when I’m calling another number (I’m on Vodafone) and we’re both in good signal areas. It’s a bit of an annoying issue. Has anyone else experienced it?
Hello
That’s an odd one.
It’s the first I’ve come across this one.
Are you still having issues with this?
Hello
That’s an odd one.
Hi Mohammed, sorry about very late reply, I forgot about this topic. Yes, it does still appear to be an issue, sadly!
Do you know if your mum has this issue calling any other numbers?
Do you call your mum or does she call you? Does that make any difference with the calls going silent?
Are you or your mum using any accessories such as Bluetooth headsets?
Is it consistently 15 minutes or any other period?
Phil
