Does anyone know when ID will be releasing the Huawei Emui10 upgrade?
It seems other servers have released them, but no ID yet.
Best answer by Kevin
View originalDoes anyone know when ID will be releasing the Huawei Emui10 upgrade?
View originalHey
Â
iD Mobile does not release firmware upgrades for phones. All phones sold by iD Mobile use retail version of the firmware, which means it is free from any network bloatware and updates are released directly by manufacturer.Â
Â
Could you advise me which phones you are using? I could check if update to EMUI 10 will be available for you soon.Â
Â
Kind Regards
HeyÂ
Â
Thanks for the reply; the mobile is a Hauwei Mate 20 pro.
Â
