Best answer by Mohammed
View originalH+ not 4g
Have just switched to idmobile from O2 which always connected to the internet using 4g on my Samsung galaxy j5. When using the SIM card from idmobile the phone will only connect using h+ which is much slower. How can I get it to use 4g instead?
Hello @Sarahjn ,
Each network's coverage can vary.
Whilst you may be used to O2's 4G coverage, iD Mobile's coverage can also vary.
Have you tried checking your coverage on: https://www.idmobile.co.uk/help-and-advice/uk-coverage-checker
This will give you an indication on the expected levels of 4G.
Why iD
Mobile?
