Mobile phone
  • 22 April 2019
  • 146 views
My mobile is falling apart and I do not think it will survive until when it is due for an upgrade in January 2020. What options if any do I have
Hi @jideh
Unfortunately ID Mobile does not offer early upgrades. You can only upgrade in last 60 days of your contract. Let's say, if your contract in ending on 1st of January then you can upgraded after 1st of November.
What I could recommend for you. Look at SIM free or PAYG deals in Carphone Warehouse as often then run pretty good promotions so you could buy budget friendly handset to last you until you are eligible to upgrade.
Kind Regards
