Best answer by Adzdalton
View originalStorage increase for Samsung J5?
I luv samsung phone. But find the battery dies quickly and storage not good especially if trying to save to an ad card. How much better is the s10?
Hey @Joyrees1 what samsung phone do you have at the moment? It's a hard to tell you exactlly how much better the s10 would be if I knew what I were comparing it too :)
I've heard good things about the battery life on this one from doing some reading up so far, but such things also depend on the users usage of the phone.
Hi @Joyrees1
The S10 comes with two variants of internal storage. 128GB and 512GB.
However the S10 plus will be the first phone to offer an aditional 1TB variant.
Both of these will accept up to 512GB micro SD of course too.
That's leading the way in phone storage at the moment.
As for the battery life, the S10 model comes with a 3400 mAh battery which is pretty decent.
The S10 plus comes with a humongous 4100 mAh battery.
I would say thats a considerable upgrade from the J5 you're used to.
Hope that helps :)
Best Regards
Adam
Hope that helps :)
Best Regards
Adam
Why iD
Mobile?
