Best answer by Gregor
View originalWifi
Hi @MsCrockofshit
In order to see if we could help I would need to ask you for some more details. Is it an iPhone device or android that you are trying to connect? Did you try to reset network settings on your phone? Is it possible that your router is 5GHz and your phone does not support it?
Okay, Nokia 3.1 support both of the WiFi frequencies so this is not going to be this issue.
What I would recommend to do is
1. Forget your WiFi connection in the settings and connect again with the correct password.
2. Go to Settings -> Network & Internet -> WiFi -> WiFi preferences -> Advanced -> turn off "Auto network switch" then reboot your phone.
3. If these steps above will fail to help you, then I could only suggest factory resetting your phone and trying to start fresh.
Regards
Regards
Why iD
Mobile?
