WiFi Calling - enabled but does not work.
  • 23 February 2020
  • 166 views
Hey guys
Usually I feel comfortable with getting most of iD Mobile features working by myself but since I got my Note 10 and my partner got S10 I really struggle to get WiFi Calling to work.  Both of the phones are factory unlocked and purchased directly from Samsung.
* I have erased and setup my phone twice to see if that will help.
* I have reset network settings multiple times even when using safe mode.
* I have checked career provisioning using #*#*4636#*#* code and toggle for WiFi Calling is on but greyed out.
* I have turn WiFi Calling on and off and test it with Airplane mode multiple times.
My phone is dual SIM so as a test I have inserted o2 and Vodafone Sims from my mates to the second slot and WiF Calling works with both of them but as soon as I change it back to iD Mobile it's not working but toggle to turn it off and on is visible.
Below is few screenshot from my research.
I hope you guys can help me here, maybe one of the technicians would know what to do because I run out of ideas.
Kind Regards
Gregor
Badge +8
Hi @Gregor
Has WiFi calling never worked with iD Mobile on neither of those phones
Could you try turning off WiFi calling in the phone, restarting your router, then turning the WiFi calling back on and seeing if the problem is the same?
Have you been able to test if WiFi calling is working on another WiFi network other than your home one?
If you've tried both the above and you see no change.
Then please get in touch through one of the following below.  We’ll then raise a trouble ticket on this on your iD Mobile account and keep in touch directly with any updates.
Reaching our Live Chat Team here: https://www.idmobile.co.uk/help-and-advice/contact-us
Facebook (https://www.facebook.com/idmobileuk/?ref=br_rs)
Twitter (https://twitter.com/iD_Mobile_UK)
Hey @Kevin
Thank You for your advise. I did not think on trying to reset the router, I shall try that tonight and will let you know.
It did not work at all since we got these phones. I will contact you by Facebook if these didn't work, it's the most convenient way for me :-)
Thank You again for your tips. I will keep you posted if I managed to get it to work :)
Kind Regards
Gregor
Wee update, I have got WiFi Calling to work. I had to flash CSC File which is specific to Carphone Warehouse and now it works as it's supposed to.
Kind Regards
Gregor
Badge +8
Interesting, could you elaborate on what you’ve done there @Gregor
Hey @Kevin
I am happy to tell my story about getting WiFi Calling to work 😃
While I was researching how I could fix it on my own, I came across an app called "Phone Info *SAM*". When I installed it and started checking things around I found section of the App that was called "Country Specific Code Lookup aka CSC Lookup" and I filtered to show me UK ones and I found this
Then I checked which version I had installed and appeared to be this one
So I googled "SM-N970F Carphone Warehouse CSC File" and came up with nothing. There was no CPW version of that file available to download.
So I asked my fellow "tech expert", he owns wee phone shop in town and he told to install "XEU" version of the Firmware and that should do the trick, so I said "that's the one I have on my phone and WiFi Calling doesn't work ".
I decided to keep researching and left it at that, but few days later he texted me to say "install "AUT" version of the firmware, which is for Switzerland but it worked for me." So that's what I did and in the settings says now that I have CSC available for CPW as well which unblocked WiFI Calling feature for me.
I don't know why Swiss version did the trick but that's where Carphone Warehouse specific settings are hiding :D
I have used Odin for any files that I flashed to my phone and Sammobile.com to download them.
Kind Regards
Gregor
