Just wondering if I order a SIM card, it will work on this unlocked mobile, it's a few years old, so just using for work
Best answer by Mohammed
Welcome to the iD Community.
Checking online, it seems that this is a 3G handset so you should be able to use this for calls and texts. The handset appears to be basic so I'm not sure mobile data/internet browsing would work.
It may be worth double checking your manual but as long as the phone has 3G compatibility, it'll work fine.
Our network supports 3G & 4G only.
EDIT: I've moved your topic to the section: Android
