Hi all
Just jumped onto another network that doesnt have 800MHZ band 20 coverge for 4g which has completely killed my indoor connection, ive seen 4g co uk site suggest 800mhz is covered but it also claimed that for my current supplier which turned out to be false after conacting them. Can anyone just double confirm 800mhz 4g works so i can have the indoor coverage i need?
Thanks!
Best answer by Will
