Best answer by Mohammed
View originalCall waiting
Can someone tell me on the sim only deals do you have call waiting? This is where if you are on a call the other call comes up & you have the option to accept or reject.
Hey there @Kellyh83 ,
Welcome to the iD Community and thanks for posting!
Call Waiting should be supported and depends on your handset also.
Most modern smartphones support this feature.
This can be turned on by dialling the below codes:
To Activate: *43#
To Deactivate: #43#
To Check Status: *#43#
Hope this helps!
To Activate: *43#
To Deactivate: #43#
Hope this helps!
Why iD
Mobile?
