I recently made some calls from tenerife. There was 0800 , 0330 and normal numbers which didn’t work. When calling these numbers a voice said these numbers have not been allocated. These numbers could be contacted on other phones. I tried on both movistar an yoigo. Is there anything I should be doing on my ID account or my phone to get these numbers as they were quite important calls at the time.
Hey
The only suggestion that comes to my mind is to replace 0 with +44 is the number is from UK. Could you try it for me and let me know if that helped? If that does not help I will do some more research to find out how I could help you. Unless
Kind Regards
Gregor
+44 should be used for all UK numbers instead of the 0
PLUS:
on your account dashboard go to My Services and check you have roaming and international calls activate!!!
I tried both ways with the same end result unfortunately.
Hello
What about when you call UK Mobile numbers, do these work?
Lastly, when you send a text, are your texts going through?
It is only certain numbers that I get the response of not allocated. I am no longer in Tenerife so I can't try that number and I believe the 7777 number has been closed down due to covid 19. Texts have worked.
