Every time I try to call a specific number the call cuts out, they can ring me and I can text them and I can ring other numbers.
Is there a way to fix this?
Okay
Is your phone listed at https://www.idmobile.co.uk/help-and-advice/approved-handsets (the list of handsets approved for iD’s network)?
No it fails in all locations and yes it is an approved handset.
Okay
Is the number you’re calling actually included in your plan’s allowances?
If the number is not included in your plan’s allowances, is your account’s bill cap large enough to make calls to this number?
I would assume so yeah, I can make to calls to other numbers.
I’d suggest checking the specific number you cannot call is included in your plan’s call allowances.
iD Mobile plan’s generally only include the following patterns in their plans call allowances:
Section 12.25 of iD’s terms & conditions states:
It is a UK mobile number
Perhaps the owner of the specific UK mobile number, which is failing, has inadvertently blocked your mobile number from calling them?
If that were the case, would I still be able to text them?
A good question - I’m not sure, because iOS and Android may handle this differently.
On iOS, the block feature blocks calls and messages from the given number.
Looking online, it appears Android works differently, allowing you to block callers without blocking messages from that caller, and vice versa.
This wasn’t the case, wasn’t blocked from the other number at all.
Okay
For real-time assistance from an iD agent, use the online chat at https://idmobile.co.uk/live-chat.
Unfortunately, the ID customer service agents only work between 9am - 8pm on weekdays - there’s a support bot outside this time period.
If you can’t use the online chat, just send a private request to iD Mobile’s social media team using facebook (using Messenger) or Twitter (by Direct Message) - the team will also be able to assist.
Good luck.
