If i wasnt living in the uk for the past 3 years but i have english card i would be able to make a pay monthly contract?
Hey
Â
As long as your bank card has been registered to UK address for minimum of 3 years and you haven't changed your British address between moving abroad and coming back to the country, you should be fine to get a contract, it's a matter of trying. Important is that you have been and you are receiving income to the bank account registered to the debit card that you are going to use.Â
Â
If you have just arrived to UK and opened the account then Pay as you go will be your best option.Â
Â
Kind Regards
I am in uk since September 2018 so i wont be able to make a contract?
Hello
Â
You’ll need at least 3 years of UK address history for a credit check.
Â
You can still explore PAYG options which do not require a credit check.
See here:Â https://www.idmobile.co.uk/shop/plans/pay-as-you-go/sim-only
Â
