Best answer by Mohammed
View originalGroup mms
Hi all, Can anyone tell me if iD mobile allow group picture sending on mms, as when I try to send a group picture, I get a pop up telling me to change my message setting to group mms, but I don’t seem to have an option for this in my message settings. I am on Android & using a Motorola G7 plus.
Hello @smashem196 ,
Open the Messages app, click on the 3 vertical lines located in the top right, choose settings, scroll to the bottom and choose advanced, choose group messaging, choose send an mms reply to all recipients.
Does this work?
One thing to note is MMS messages are not inclusive of your plan and cost 30p per MMS message.
You'll need to have raised your spend cap to allow these messages to send.
Does this work?
Why iD
Mobile?
