Best answer by Kevin
View originalhelp...
My phone speakers are working with music and through aux. Calls are working but only through an aux speaker. But calls arnt working through my own phone speakers. Why is this?
Hi @Gracesteer , do you have any Bluetooth items connected or, during a call do you see the option to route the call to internal/ external speaker or bluetooth device.
-Phil
-Phil
Hi, unfortunately nothings working still. I also can’t connect my phone to aux in my car but my friends can
What phone is it that you are using @Gracesteer ?
It might be worth backing it up to a computer (to save your pics etc) and then doing a factory reset to see if perhaps it's a setting that has changed here that's causing this weird inconsistency.
Failing that, it would be worth speaking to someone in a local Carphone Warehouse store to see if they can potentially fix the issue simply through the settings. Or at least diagnose what the problem is if it's something else.
Why iD
Mobile?
