Hi all,
I would appreiciate some help. My A51 says ‘unable to connect’. I can’t make network calls or use 3g/4g when out and about.
I have looked on-line and can’t find anything.
Thank you
Hi all,
Thank you
We’re sorry to hear this
Have you tried the phone in various locales? (i.e not just at home)
Have you restarted your phone in the past 24 hours?
Could we get your current postcode to check for any known issues with your local masts?
