Best answer by Mohammed
View originalIs there a Minimum amount for data roll over
Is there a minimum roll over for data? I know some companies have a 1gb minimum so if I had only 500mb it wouldnt roll over. Just wanting to know before I sign up. Thanks
Hi @Rose
ID Mobile does not have minimum data to rollover, any leftovers will be available for next month. Even if it is just 100mb.
Here is a link to FAQ page where you can read more about Data Rollover and others features.
Kind Regards
Kind Regards
Hey
As
So in your case, you cant roll-over more than 500MB of data.
If you did roll over 500MB (giving you 1GB for the month) and didn't use any data, then only 500MB would rollover.
Why iD
Mobile?
