messages error
  • 13 June 2019
  • 6 replies
  • 199 views
Whenever I text someone it says message not delivered even though it has delivered.Why? How do I fix this??( it only happens with one person)
Userlevel 2
Hi Slakes123
If you have an iPhone, can you check that the number recorded in "Settings > Phone" as a mistake here can sometimes cause this problem.
Phil
Hi, I have the same problem with my text messages - only it happens to me with all of my numbers except one! I've checked the phone number in 'settings' on my iPhone and that is correct, so I can't understand what's happening
Hello @Oceandream57
The the following:
1) Try turning off iMessage (Settings > Messages)
3) Tap Settings > Phone > My Number and change the number to a different number.
4) Restart then change the number back to the correct number that's active
6) Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:”.
Let us know how you get on.
I have the same issues.
My old number is still showing in my settings.
when I delete enter and save my new number it won’t save.
@Jan Thompson,
Are you using an iPhone?
Can I ask if you have tried resetting your network settings then trying again?
yes it’s an IPhone 13.
I have sorted the problem thank you,
you did help to a point.
I then restarted my phone and it changed the number in settings.
Regards Jan.
