Hi @Tracy Hall Was Tibbott, welcome to the community!
It sounds like your mobile number may need to be updated in the messaging settings. I’ve left some steps below that should fix the issue:
For iPhone:
If you are having issues with step 4 please reset network settings and try again. Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
For android:
2) If it shows the incorrect one, then head to: https://messages.google.com/disable-chat and you should be able to unregister the number. Once done, turn off the Chat Features/RCS and the phone. Wait a few minutes and turn the device back on and re-enable Chat Features/RCS it should let you re-register/update to the correct number. Alternatively, you can turn Chat Features/RCS off and test SMS after this.
-Lauren
