HI
ONLY HAD SIM FOR 1 WEEK AND GETTING "NO SIM" AND
"NO MOBILE NETWORK"
TRIED TURNING ON OFF TRIED TAKING OUT SIM AND PUTTING
BACK STILL SAME PROB. WILL HAVE TO CANCEL IF NOT SORTED
NEED PHONE FOR WORK
CHECKED RECEPTION IN AREA AND IT GOOD
NOT HAPPY
Hi 1DAISYDOG, if you get a message that says no SIM this likely indicates a physical problem with the SIM or phone.
Are you able to check the SIM in any other phone to test this?
Are you also using a phone that is 3/4G compatible as if not, this could result in no network, even if the SIM was fitted properly.
-Phil
-Phil
Why iD
Mobile?
