Have turned phone on and off several times but no long term results - goes back to WIFi only- any clues
Best answer by Michelle
View originalHave turned phone on and off several times but no long term results - goes back to WIFi only- any clues
View originalHi
We are sorry to hear that. Have you tested the sim in another phone to see if it works?
-Mohsin
No I will try that thanks
Hello- the same has happened in a different phone- it shows 4g as normal for a 2 - 3 minutes then back to 3G only and does not make calls or have internet
Â
We’ll need to send you a new SIM card.
We’ll send you a private message on here so that we can verify your details.Â
To view the message sent. Simply click on your profile icon in the top right, then go to your private messages.Â
Â
Thanks.Â
Â
MichelleÂ
iD MobileÂ
