signal
  • 9 June 2021
  • 9 replies
  • 74 views
Hello I am really struggling to get a signal in shops etc this had been going on for a while and it us not great
Can anybody please help thanks
Best answer by WelshPaul 9 June 2021, 21:49
Maybe try doing a network reset...
What phone do you have? On my Samsung device it’s here:
Settings > General management > Reset > Reset Network settings
Also, enter your post code below and check for any know problems in your area:
Hi @Tracey Hale
We are sorry to hear this. Do you experience the singal issues when at home? Or is it only when you are out shopping? Usually when in supermarkets, the singal can vary due to the big metal framed buildings. The result is that a metal box or cage can effectively block all electromagnetic signals from outside.
-Mohsin
Hi no it is at home as well it needs resolving
Badge +2
Badge +8
Hi @Tracey Hale,
Did you try @WelshPauls advice? How are you getting on with this now?
Will
Hi yes done a factory reset not.working still indeed to speak to somebody ar customer care not responded sooner as I cannot get a signal thanks
The phone is A Samsung galaxy a20 thanks
Badge +8
Hi @Tracey Hale,
How many bars of signal are typically showing? Is it everywhere you go, or is there ever good signal anywhere?
Will
Same I have an iPhone 12 and as soon as I go indoors to any building I have no service
Hi @Traynor,
I am sorry to hear that. Have you checked out the area on our Coverage Checker here to see if the signal is limited in those areas?
