Hello I am really struggling to get a signal in shops etc this had been going on for a while and it us not great
Can anybody please help thanks
Best answer by WelshPaul
View originalHello I am really struggling to get a signal in shops etc this had been going on for a while and it us not great
View originalHi
We are sorry to hear this. Do you experience the singal issues when at home? Or is it only when you are out shopping? Usually when in supermarkets, the singal can vary due to the big metal framed buildings. The result is that a metal box or cage can effectively block all electromagnetic signals from outside.
-Mohsin
Maybe try doing a network reset...
What phone do you have? On my Samsung device it’s here:
Settings > General management > Reset > Reset Network settings
Also, enter your post code below and check for any know problems in your area:
Did you try
Will
Hi yes done a factory reset not.working still indeed to speak to somebody ar customer care not responded sooner as I cannot get a signal thanks
How many bars of signal are typically showing? Is it everywhere you go, or is there ever good signal anywhere?
Will
Same I have an iPhone 12 and as soon as I go indoors to any building I have no service
I am sorry to hear that. Have you checked out the area on our Coverage Checker here to see if the signal is limited in those areas?
