Sim not provisioned
  • 6 August 2018
  • 1296 views
Hi, just upgraded to Nokia 6.1, fitted new SIM, set up phone but data not operative. Notification stated "SIM not provisioned" ?????
Best answer by Mohammed 7 August 2018, 13:29
Hello @Holmesdx,
If you processed an upgrade, you may have received a new SIM with this. In most cases with an upgrade, the new SIM is blank and not active.
Are you able to try your old iD SIM in the device?
Thanks, but sorted out. All the swap over info came late after which I'd already figured it out. You nailed it by the way.
Userlevel 4
Great to hear you're up and running @Holmesdx!
Hi Mohammed, I'm having the same problem..
Hey @JasonNicol,
See below:
Hello @Holmesdx,
Can you let me know if this works?
I upgraded my contract on 10th December 2020 and the operator said I can keep using the same sim card. Since then it has been saying ‘sim card not provisioned’. I tried to restart the phone and the app a few times, but not any better. It just not possible to get in touch with some of the operators on the phone, the live chat button doesn’t turn up……. It is so frustrating that since then I have been unable to use my phone. Can you please help me out ASAP!!!!!???? I can’t run my business……..
Hello @svet,
I’ve replied to your other post on the Community.
