I would like to try wifi calling on my Samsung Galaxy A21s by getting a sim card -- and then if it works well, I wolud want to transfer my exisiting number so that I can keep it.
Is this possible?
Best answer by Mohammed
View originalI would like to try wifi calling on my Samsung Galaxy A21s by getting a sim card -- and then if it works well, I wolud want to transfer my exisiting number so that I can keep it.
Is this possible?
View originalHello
You can certainly.
When you purchase a SIM card from us, you’re not required to port your number.
If you buy from our website, you’ll have 30-days change of mind so test away and then if you’re happy to go ahead, simply port your number over.
Thank you
