Unable to contact ID mobile to help with reinstating my Contacts | Join the discussion, ask questions, share advice.
I lost my Contacts when i had to reset my phone. Can ID mobile help to reinstate it?
Best answer by Rory 1 July 2022, 14:55
I don’t think so @Chris Taitt.
If you’re using an Android phone, they might be in a Google backup for your phone.
If you’ve got an iPhone, they might be stored in iCloud (in Contacts).
Do a Google search for “how to restore phone contacts”, although this will only help if you backed them up before.
Hey @Chris Taitt, if the contacts are stored on your iCloud, then it should just be a case of logging in to your iCloud account and downloading them.
Otherwise, you may be able to sync them via iTunes by plugging your phone into your laptop.
Rory
