Unable to receive calls from networks other than iD since PAC number change
  • 31 August 2019
  • 194 views
I can receive calls and texts from iD accounts but not any other networks - including landline. I am a new customer to iD and it's not looking too good as my mobile is now useless. Any ideas?
Best answer by Mohammed 2 September 2019, 17:46
Hello @RobertoG,
Try restarting the device. If this doesn't work, you'll need to get in touch with us via
We'll be able to raise a ticket to our Technical Team to investigate further as it's possible the port has only partially completed.
There's not much more general advice I can suggest trying from this platform.
Userlevel 2
They could help you.
My son as a new phone with ID his old number has transferred today he is able to make calls but not receive calls?
Hi @Dominic#1
This usually does happen as the porting process has not been comepleted. Is your son still having the same issue?
-Mohsin
