voicemail not working after changing ringtime
  • 17 February 2021
  • 8 replies
  • 185 views
I’ve shortened the ring time on my phone and now when someone calls and I don’t answer it says the number is not recognised. I’ve checked the settings in the phone app and all seems to be in order. I’ve switched off and back on again but it is the same. Can anyone help solve this issue please.
Best answer by Michelle 20 February 2021, 12:43
Badge +8
Hi @Milkygraeme,
What method did you use to shorten the ring time?
Will
Hi Will
I did
**61*123**20#
And also tried
**61*447782333123**20#
Graeme
Hi @Milkygraeme
Please try **61*333**20#
Let us know how you get on.
-Mohsin
Hi Mohsin
No it didn't work.
The caller still gets number not recognised message  ☹
Userlevel 5
Badge +8
Hi @Milkygraeme
This looks like it was answered already here:
https://community.idmobile.co.uk/android-26/callers-told-number-not-recognised-instead-of-going-to-voicemail-30079
Please let us know how you get on.
Michelle
iD Mobile
Thanks Michelle but still no joy. I have samsung a10 and the voicemail number is set what seems correct but it won't allow me to change it anyway
Graeme
Hi @Milkygraeme
We are sorry to hear you have still unable to get this to work. Please can you check your voicemail settings to see what the number shows as? Can you also try to turn your Voicemail off and then back on again. You can do this through the iD App.
-Mohsin
😀 sorted now. Thanks
