Wifi Calling issues
  • 20 May 2019
  • 375 views
I have a iphone SE and have good wifi at home but poor 3g or 4g coverage. I have wifi calling enabled in settings but all I get is No Service in the corner of the screen.
Best answer by Gregor 21 May 2019, 14:33
Hi @pzdavis
Just to make sure, did you update your iPhone to the newest available system? For Wi-Fi calling to work, system need to be all up to date. You can check it under Settings -> General -> System update.
Kind Regards
I updated to the latest version of iOs 12.3 and this seems to have fixed things. Thanks.
