Charge for using Zoom
  • 3 April 2020
  • 253 views
I have a £5 sim only contract.   Will I be charged extra for using Zoom or other conference call Apps?
Best answer by terrywebbs 5 April 2020, 15:37
@Jillym depends on the app provider and how their technology works.
Data charges are incurred for all apps that use the internet, it is advisable to use wifi where you can to reduce extra data network charges!
The Zoom app is free to use on the basic plan but it uses your data allowance… check out the terms and conditions of the apps you require then check your network allowances.
