I have a £5 sim only contract. Will I be charged extra for using Zoom or other conference call Apps?
Best answer by terrywebbs
View originalI have a £5 sim only contract. Will I be charged extra for using Zoom or other conference call Apps?
View originalData charges are incurred for all apps that use the internet, it is advisable to use wifi where you can to reduce extra data network charges!
The Zoom app is free to use on the basic plan but it uses your data allowance… check out the terms and conditions of the apps you require then check your network allowances.
