Best answer by Phil
View originalData Rollover incorrect allowance?
i had 6.2 gigs data remaining why was only 5 gigs rolledover?
Hi Destiny, are you on a 5Gb monthly plan? Data can only roll over for 1 month so you may have the maximum that can be rolled over.
yes i have 5gb monthly plan last month was given 5gb rollover plus my 5gb allowance so got 10gb. but only used 4gb so i should of got 6gb rollover and 5gb allownce that should be 11gb but only got 10gb?
Hi @destiny7 ,
As advised above you can only rollover 1 months allowance at any given time.
This means the maximum you could rollover would be 5GB.
well thats c**p time to cancel Contrack not 4 me
Why iD
Mobile?
