Please, is it possible to get my phone records if my phone was disconnected on 3rd of December?
Best answer by Mohammed
View originalPlease, is it possible to get my phone records if my phone was disconnected on 3rd of December?
View originalHello
Â
Can you clarify if you’re after a recording of the calls or if you wanted a record of the numbers you dialled?
We don’t record calls, unless it’s a call you made to us directly.
If you’re after a record of your calls, these are viewable in your PDF bills, usually page 2 onwards for the breakdown.
You still have access to your account even after disconnecting for 6-months so should be able to view this.
Â
Let us know if you need any help.
Â
Thank you, that helped a lot. Can you get my messages contents please?. I logged in and now I see all my phonecalls but could I get messages contents?
Thank you
