Hi. I currently have an ID Mobile plan with 9gb data and am looking into upgrading to a plan with unlimited data. Does the ID mobile unlimited data plan have a fair usage cap?
thanks in advance for your help
Best answer by Emil
View originalHi. I currently have an ID Mobile plan with 9gb data and am looking into upgrading to a plan with unlimited data. Does the ID mobile unlimited data plan have a fair usage cap?
Best answer by Emil
View originalHello
You can check this here: https://www.idmobile.co.uk/help-and-advice/eu-roaming/fair-usage-policy
If you’re referring to Fair Usage policy on Roaming.
If you mean in general, such as is Unlimited actually a set limit, then no, we do not have a Fair usage policy on data as far as I know.
I hope you’re well? I wanted to check on your wording in the last response.
You’ve said you do not have a Fair Usage policy on data as far as you know.
I hate to be a stickler but I need to have 100% confirmation as I’m going to probably buy another SIM to be my mobile hotspot. Can you please confirm absolutely that there is no contractual clause etc with a limit on non-roaming data?
Kind Regards,
Red
