ID accounts. Pac code not working due to same network.
  • 23 November 2020
  • 38 views
How do I transfer over my number from my rolling sim only to contract sim only? Both with ID and pac codes not working due to it being the same network
Best answer by Ryan 26 November 2020, 20:43
Hi @AKemp1,
Unfortunately this is not possible, you will have needed to upgrade your current number to a new plan in order to keep your number. Would you need help with a return or a cancellation due to this?
