My phone has basically unusable as a phone as I rarely have any signal at all so I can't have any phone calls in or out. For example, the other day I had an important call from my doctors but due to signal issues the doctor couldn't hear me at all. I
Best answer by Michelle
You will need to use the SIM card eject tool to remove your SIM card.
If you look on the side of your phone you will see a small hole, the eject tool needs to be placed in here to open the SIM tray.
Michelle
