Don't seem to have data this morning. Anyone else having the same issue?
View originalDon't seem to have data this morning. Anyone else having the same issue?
View originalHello
Have you checked for any network problems in your area using the following page:
Good luck.
Thanks. It was saying all okay earlier but now showing a problem 👍
That’s bad luck - is it the 5G BIG BUILD happening or another issue?
The 5G build project work can last for several weeks.
