Poor data connection...what is the solution?
  • 15 June 2021
  • 9 replies
  • 392 views
The WiFi reception is extremely poor at home and also when I’m travelling often and using Sat Nav.
Best answer by WelshPaul 16 June 2021, 09:43
Userlevel 5
Hi @BJ Sheridan, I’m a little confused by your post, I’m afraid. When you say Wi-Fi reception, do you actually mean your network coverage? Wi-Fi is provided by your internet service provider, and it’s typically something you connect to when you’re at home or in a public place, like a café. It’s not really something we’d expect you to be using while travelling around or using sat-nav.
Do you mean your network coverage/data reception?
Rory
Thanks, Rory.
At home, the data reception/network coverage is so poor often e-mails won’t open. It’s hugely frustrating.
When travelling, I use google maps on my phone as my sat nav so am using the same WiFi and it often cuts out. I have a large data bundle and use my phone as a tethering hotspot for my laptop.
Best
Barbara
Hi @BJ Sheridan
Enter your postcode on the pages I have provided links below and let us know the results.
Check the network coverage in your area:
http://www.three.co.uk/Discover/Network/Coverage
Check for any network faults/issues in your area:
If there is good indoor/outdoor coverage and no network issues reported in your area then try doing a network settings reset on you phone. What phone do you have?
On my Samsung Ultra 5G device it’s here:
Settings > General management > Reset > Reset Network settings
If there is no to little indoor/outdoor coverage on the coverage map or there is a network issue showing in your area, enable WiFi calling if your phone supports it.
Thanks very much for your helpful advice @WelshPaul
Network coverage in my area is good apparently. However, there is work on masts being undertaken which is the problem and is causing disruption.
Hopefully the work is completed soon. 👍
Userlevel 5
Hi @BJ Sheridan, just to clarify and to avoid any confusion in the future, a Wi-Fi connection (provided by an internet service provider like BT or TalkTalk) is not the same as your data connection, which is provided by us, your mobile network.  They’re completely independent.
We do hope the mast works are completed soon! If they do continue for an extended amount of time, though, feel free to reply to this post and we’ll be happy to discuss recompense.
Rory
Network Coverage indoors is very poor, never gets above 1 bar. I have WiFi calling enabled. Outdoors is fine when I go away from the house or in the garden. Are there any suggestions to get better signal strength when inside the house?
I was on o2 and did not have this problem at all, only since I’ve moved over to ID which has been 4 months now, and its super frustrating
Using an iPhone 12. Postcode: MK8
Thank you!
Userlevel 5
Badge +8
Hello @Hemz21
Unfortunately, no network can tell you exactly how strong your signal will be when you're indoors at home, work, or in any other building.
This is because the signal strength needed to pass through walls and windows varies from building to building.
By enabling WiFi calling whilst indoors will help improve your service.
Michelle
iD Mobile
Hello @Hemz21
Michelle
iD Mobile
Thank You @Me 1973
