I have had no signal today is there an issue.
I live in Chipperfield, Hertfordshire
Hope you can help
Susan
Best answer by Mohammed
View originalHi
Hope you can help
Susan
View originalCan someone please let me know why I have no coverage. I am going mental here to find out how to answer a simple question
I am having the same problem postcode wd4 9js
Hello
sorry to hear you’re having trouble with coverage.
We’re happy to look into this for you.
What’s the full postcode of the area?
We can check the local masts that provide coverage to get an understanding of what’s causing this.
Hello
I’ve merged your topics together, please keep all posts regarding the same issue within the same topic.
Hello
Thanks for confirming that postcode for us.
I can see that the area shows Good Outdoor with Marginal Indoor coverage on 3G and 4G is varied.
The local mast shows no unplanned outages.
The neighbouring masts show congestion and some recent unplanned outage though it’s unlikely this is the case.
Have you tried restarting the phone?
Thanks for getting back to me
I do find it confusing to find the right place to ask a question
Yes I turned my phone off and restarted no problem with signal
Thanks again
Susan
Glad to hear it’s working now
If you do need any help with the same coverage problems just reply to this topic.
You can usually find your topics if you click your profile icon and then click on your profile.
Your Icon currently will be the beige circle with the S in it.
Most helpful
