Unable to connect with phone calls
I am on holiday in the south of Ireland when I receive a call everything ok but if I try to return that call I am getting a message saying the phone number is not recognised
I am on holiday in Ireland and I am receiving calls but if I try to return the call I am getting a message saying the number I have dialed is not recognised.
Hello @Tributeact ,
Welcome to the iD Community.
When you say "Southern Ireland" are you referring to the "Republic of Ireland"?
This would be classed as Roaming, so when you're calling, you'll need to make sure that the number has +44 replacing the 0.
For example, if you were calling 07771234567 in the UK, it'll be fine, but when you're Roaming, you'll need to dial +447771234567.
Hope this helps.
EDIT: I've moved your topic to the section: Coverage, international & roaming
EDIT 2: I've merged your second topic with this one here. Please refrain from creating multiple topics surrounding the same issue.
Hope this helps.
Why iD
Mobile?
