I have an iPhone 5s. Wifi calling works but I am having some issues.
Basically at home I have a good wifi signal and poor ID Mobile signal. Wifi calling works but is erratic.
The issues are
- Sometimes the phone is on ID mobile but with low signal strength and poor reception in use.
- Sometimes it goes to wifi calling
- Sometimes it says “no service” despite there being a good wifi signal
The other issue is that sometimes the battery to drains very quickly, from 100% to 40% overnight with no calls made. Other times the battery drop overnight is far less. I suspect that the phone is on wifi calling or no service and is trying to find a mobile signal.
My first question is what is deciding the connection choice between the mobile signal and wifi. Is it the iPhone ( Apple), ID Mobile or the 3 Network.
My second question is can I amend any settings so that at home it will automatically connect to wifi calling. I know about going to airplane mode and that does force wifi calling but then I leave the house and forget to switch of wifi calling.
Any help would be appreciated
Best answer by Ryan
