zero call coverage
  • 2 April 2022
  • 64 views
I have been having signal issues for over a month now which is very frustrating. I have calls which start and then cut out and carry on or calls that just cut off. I.have checked my coverage and its really good so insure what the cause is.
Hello @mamunro81,
Have you checked for any service disruption of ongoing maintenance and repair activity in your area?
Check for this using the three network status checker.
Anyway, good luck.
Userlevel 5
Hi @mamunro81, just checking in to see if you managed to use the service checker posted above? What were the results?
Rory
