Hello all
When I go into phone settings there is no option to set up call forwarding.
Google Pixel 6 Pro
Anyone else have this issue?
Many thanks
Hello all
Google Pixel 6 Pro
Many thanks
What exactly is it you’re trying to do? Are you just trying to set up Voicemail?
Will
I wanted to send calls to my wife's phone while I'm asleep after night shifts.
Thanks for answering.
Martin
Thanks for replying.
Under Phone > Settings > there is no ‘calls’ option.
I have checked the options available and there is nothing under those.
Is the feature blocked by ID mobile?
Are you able to search in your settings app?
If so could you search call forwarding to see if that comes up?
No results for call forwarding or forwarding.
Please could you click on settings and call and send us a screenshot of what shows?
It should usually show in your settings.
Cheers
Have you checked to see if you’ve got the latest update for the handset?
I’m aware there was a day one update, this may be the reason it’s missing.
Will
Yep :)
Just did a live chat with Olewuth and they were unable to help. Told me to contact Google. Which I don't find very good customer service to be honest. I am still within my 14 days and am very tempted to return handset and terminate contract at this point. You two have at least tried to help.
Ok. Went to Google and got the answer.
Phone > settings > Calling Accounts > Sim1 ID > call forwarding.
Hope this helps someone else.
However ID should really be able to support their handsets that they sell.
Thanks for all the replies.
Stay safe.
