I lost my phone and my SIM card is there anything I can do to get another phone and SIM cardÂ
You should report your phone & SIM as lost, otherwise you’ll be liable for the bill.
Ask iD for a replacement SIM when you report the loss.
You can claim on your insurance if you’ve got cover for mobile phones, otherwise you’ll have to replace the phone yourself.
Â
Â
Thanks for the reply. I’ve not got insurance đŸ˜” when I get a new phone will I be able to use my id mobile SIM card in new phone? ThanksÂ
Hey
If you do get a replacement SIM from iD, you should be able to use it with any unlocked (SIM free) phone.
However, it might be worth checking the iD Mobile list of approved and compatible handsets before getting another phone.
Good luck.
