Extend internal storage
  • 2 October 2018
  • 106 views
How can one extend the internal storage on a 'phone? I have a Kazam Thunder Q45, a comfortable and useable device, but the internal storage is so small that I can't install apps or use the camera. I don't store lots of picturers or data and I have tried uninstalling apps I don't use, but am wary of deleting anything that brings up a message, 'this may affect the function of your 'phone'.
Would appreciate any help!
Best answer by CFHeadphase 2 October 2018, 12:57
I've looked up the phone's spec, and it has a microSD slot accessible by removing the back plastic cover. Buy a microSD card, insert it and you'll have more storage available to you.
Thanks - I'll give it a try and let you knolw if it helps.
