I'm planning to use roaming in Spain shortly. I've set roaming on for my phone and my ID mobile account.
I checked my APN settings and found a minor anomaly. All the settings are correct except the name field.
Mine is set to ..... iD Mobile as opposed to just iD.
I'm assuming this isn't a problem as it only defines how it appears in my list of APN's but I thought I should check. (I don't seem to be able to edit it so I would have to add another APN definition if necessary.)
Any advice would be greatly appreciated.
Best answer by Mohammed
