Best answer by Mohammed
View originalCan i ring the Uk from Israel and how much does it cost?
Hey @Snoopy ,
You can certainly call the UK from Israel.
The above page will give you a breakdown of charges for specific countries you'd like to find out the rates for. It's a good thing to check this before you go abroad and unsure what the costs would be.
Calling UK from Israel would cost £2.40 per minute from your iD SIM/Mobile.
Yikes, It may be worth connecting to WiFi and calling via Skype to Skype or Whatsapp to avoid any unwanted charges.
Remember, if you've got a spend cap set up, you'll only be able to make calls until this cap is reached. This means you might have to increase the cap to continue making calls.
Why iD
Mobile?
