Connecting to id in New Zealand
  • 4 November 2019
  • 8 replies
  • 1485 views
is it possible to use my id number in New Zealand?  I can’t connect at the moment.
regards,
Mark
Best answer by Mohammed 4 November 2019, 15:28
Hello @Travelling Man
New Zealand isn’t an inclusive Roaming destination as found here: https://www.idmobile.co.uk/help-and-advice/eu-roaming so you can’t use your phone here like you ould in the UK for free, however, we do support Roaming in New Zealand and this would be with a charge.
You can find the charges below:
Hi Mohammed,
thanks for your reply.  I understand that, but which network do I connect to over here?
Mark
Hello Mark,
It’s the Spark & 2Degrees network we support.
I hope you do not mind me asking a similar question about New Zealand.
I have a lot of my bank accounts and other apps linked to my ID mobile number. Such that when I log in, the bank and other apps will send me a text for a code to enter. Will I still be able to receive these text messages in New Zealand using my ID mobile number?
Hi @Mia Yap
I don’t quite see why you’d have any issue receiving these texts, as long as roaming is turned on you should be okay!
Will Id mobile contract handsets accept SIM cards from the 2 named NZ providers earlier in this topic.
I don’t know, but these two NZ mobile networks probably have a list of supported handsets on their respective web sites - might be worth taking a look online.
FYI, the current list of international roaming partners, in the “Where can I use inclusive roaming?” community FAQ, shows Spark and NZ Communications as iD Mobile’s roaming partners in NZ.
