Best answer by Chloe
View originalData Roaming and cruise ships
I'm lucky enough to be going on a cruise to the fjords tomorrow and it says in the ship information that if "your service provider has a roaming agreement with Telenor Maritime you'll be able to make and receive calls etc." Does anyone know if ID do? If so, any idea of the charges? Thanks
Hi there @Kevin C
If you use data while on a cruise ship you will be charged roaming fees.
You can find more information about this here (just select roaming, then 'Ships, Ferries, Cruise Liners' in the drop down menu:
International Calling & Roaming Charges
I hope this helps!
Chloé.
I hope this helps!
Chloé.
Thank you Chloe, certainly won't be using that unless it's an emergency. Managed to use European roaming in port so that's enough, especially as I'm on holiday
Why iD
Mobile?
